Hello, I just started up my dad's mk3 that has been sitting for 10-15 years. My problem is that when idling, my rpms will drop down to 500-400 and then shoot up to 1500 or so and then it drops back down to 400 and does the same thing. Any help would be greatly appreciated!
1987 Toyota Supra
Could be all kinds of things.
Vaccum leaks, intake tract leaks, IACV sticky, shit fuel, clogged this that or everything.
Got any other information?
It's going to need a lot of attention if it's been sitting around that long.
Yes, I should have clarified some things:
1. The gas that I put in there is new- I cleaned out the old gas in the tank and replaced the fuel pump and filter
2. All of the vacuum hoses are where they are supposed to be- I will check for leaks
3. I replaced the spark plugs and starter
4. There are no leaks in the fuel lines
I will look into what you previously mentioned. I appreciate the help!
1987 Toyota Supra
If you are for certain no vaccum leaks are present and the AFM is measuring ALL airflow going into the engine. (No unmetered air)
I would start with removing and cleaning the IAC.
The actuator might be sticking.
Otherwise there are a host of other things that may cause this as well.
Does it cold vs hot? Or all the time?
It's hard to say because last night was the first time it's started up, so I'm not sure if it would do that when it's warmed up. I didn't want to risk damaging anything so I turned it off when I noticed it was being strange
