·This past weekend I finally got my car back together, with the exception of one problem. It leaks fuel from the rail. The bolt by the #6 injector that holds the fuel on is stripped.
I re-tapped it with a 8mm x 1.25, but the threads were damaged to bad and the bolt would not hold. The next tap size I have is a 9mm x 1.25, but this will require some drilling I think and I have no idea what size bit to use.
Any suggestions on what I should do? Correct size drill bit?
Thanks in advance,
Eric
Thanks in advance,
Eric
