1 - 19 of 19 Posts
Ok, I was driving the other day and heard what sounded like a exhaust leak. So I checked the whole exhaust system to find nothing. So I started the car to see if I could find the location of the leak, and I did. One of my bolts to the exhaust manifold was loose, so I tighened it up. At this time I decided to tighten them all. I had no problem until I got to the last one, at the rear of the exhaust manifold. When I started to tighten this one it wouldnt get tighter, and I notice that the stud was coming out with every turn. So I unscrewed the stud to find threads coming out with it. FUCK!!!! Can I fix this. The stud is not stripped it's the damn head that is stripped. Need help. Pease
BoostAddict4Life
pull out the stud get a head bolt, cut it about half way down, retap the head for 11mm by 8.5 i belive, get a nut that goes onto the head bolt.
Read Only
HTB said:
were is a good place to get one big stud though?
Your local gay bar should have one :bigthumb: Nah joke seriously your local NAPA store will have everything from bigger studs to tap and dye sets. everything you need.
Chris
Over Medicated
Or you could get a helicoil kit. That way you can still use the same size stud and don't have to fool with different size studs and bolts. Just another option...
Hardtopper
I would just use a helicoil... That has happened to me in the past with my old supra and I helicoiled it and had no problems.
Ditto on the helicoil....been there, done that many times on various places and always had great results.
feeding your habit
helicoil.
How many times does fixing something that ain't broke result in this scenario?
feeding your habit
cool/hot doesn't matter..... god invented torque wrenches for a reason.
If you don't know how to tap a hole, or use a helicoil, have someone else do it, otherwise you just made a fixable problem a much more involved problem.
1 - 19 of 19 Posts
