Any aftermarket MKIV axles available? I will be running a TRD diff, and will be buying fresh axles. I know stockers are strong, just thought there was an upgrade available. Thanks.
I used to work for Hahn Racecraft. The Driveshaft Shop built "custom" FWD Stage 3 axles for our 11-second Eclipse. They both broke on the first waterbox burnout...
They also said they are not making custom axles for RWD apps. Strange Engineering said they are not interested in making ANY import axles. Fuckers...
I may have a new stock set cryogenically treated and see how that works.
Dan, if you're so worried about broken alxes why dont you get a ford 9" for that th400 monster.
If you'll be satisfied with sub 1.4 sixty foot times you dont need to worry about the axles.
