1 - 4 of 4 Posts
Supratruck Pilot
Anybody had one of the ebay HKS clone wastegates go bad? Today, after boosting my truck for the first time, I'm now venting out the wastegate all the time. I guess the valve in the wastegate is stuck open or something. I've tried emailing SSautocrap several times in the past about other issues and never got a response so I'm probably wasting my time complaining to them. Is there an easy resolution to this or do I need to buy another wastegate? Can they be torn down and rebuilt? By the way, I only saw 8 lbs. of boost and it broke my monster rear tires (16" wide) loose going into second. I can't wait to see what 30 lbs feels like :)
2jz powered
good to see you boosted your truck. i have zero experience from the ebay wastegates but have seen a simillar gate. i believe they can be taken apart and rebuilt. i personally would just go with a tial and not have to worry about the wg failing.
T88 YOU
im sure you have spent lots of money on your truck, why cheap out and use a wastegate that your not sure works any better than a styrofoam cup? i would just get a new wastegate and sleep rest assured at night knowing your wastegate will work the next day. i really wana see what your truck can do so hurry up and get a new wastegate and crank the dang boost up!!!
Supratruck Pilot
Normally I wouldn't have went the "cheap" route but until now I hadn't heard anything negative about this wastegate. Everything I had read said that it appeared to be identical to the HKS unit. I'm going to take it apart tomorrow to see if I can see any problems. If not, I'll probably get another.
1 - 4 of 4 Posts
