1 - 20 of 23 Posts
· 2005 LP640
Fucking piece of shit car......no matter how much you dump into it you never make it happy.
Went out today to fix the popped hose running from the back of the head to the VSV, and put it back on......fixed that.
Checked underneath the car to see why the speedo wasnt working: Fucking cable is popped apart. Try putting it back together to no avail. So speedo is still broken.
Tightened the lower sensor on the T-stat housing, and it's STILL fucking leaking coolant.
To top it off, the dipstick won't stay in its fucking hole because Sound Performance didn't include a bracket with my SP61 kit. So joy, now I can't even drive my fucking car for a while until I have a new speedo cable since I have to go through EMISSIONS.
So I now need a damn speedo cable, and a new lower sensor. Bitch ass car.
· JZA70 or go home!!
BHG
go to the junk yard find a speedo cable
· Republican
Or just buy a new one....which is a better idea anyways.
· Destroyer of Turbos
:agreed: people need to stop trying to nickle and dime shit by replacing it with old parts... buy a new one and be done with it for another what? 100k miles...
· Buddy thought I had a NA
dude the coolent thing is easy to fix juse use soem tefole tape or liqed it fix it right up
speedo cables break in these car easy cause there at such angle i re rooted mine better so it wonte break
Drill a hole in your turbo heat shield, tap it and put a screw threw the hole. You can also just use a screw and nut to mount the oil stick. Put some gasket stuff around the oil stick where it goes into the block.
Maybe he doesn't have a tap and die set? Then again I guess you don't need the dies but you gotta have a tap.
I think it would be funny to watch someone read this who has no idea what a tap and die set is... "What's a tap and die set? you tap someone and they die or something?" Hehehe. And I don't care if I'm the only one who thinks that would be funny.
-Dave
· Not ur jizz, not ur bizz
aww come on 87turbosupra...this is petty shit..no big deal dude. Nothing to make a thread about. shit happens, fix the lil things..its all good :)
i thought it was gonna be something dramatic like you started your car and you got a rod knock or something
· Premium Member
hey it happend to me :(
· 2005 LP640
Discussion Starter · #17 ·
Um no...........not a BHG. :D
Anyways got that stuff fixed. Now all I need is a damn speedo cable new from toyota. Should come in in a couple days, after that its time to go through emissions
*crosses fingers*
1 - 20 of 23 Posts
