1 - 2 of 2 Posts
Say you have a wastegate with a 15psi spring. How then, does it stay closed when the exhaust pressures pushing against it are typically in the 40-60 psi range?
2JZ swapped!
I think the 15psi means the pressure on the cold side not the hot side.
1 - 2 of 2 Posts
