I have a broken (at the plug) sub TPS (the one on the other side of the trac accuator). I was wondering if it had any effect on the way the car will run if it is just left unplugged. It as of right now doesnt seem to have any effect on the car but just wanting to know from ppl that have a little more "know". Thanks.
P.S. I have the trac disabled.
If you have the trac relay pulled, then it wont make any difference, may or may not give a warning light, i am about to fit a throttle body that i have removed the trac butterfly. motor and position sensor, and if that gives me a check light i will just remove the trac ECU.
