1 - 12 of 12 Posts
GIT-R-DONE YALL HEAR
ok guys here is my problem. whenever i turn my a/c, heater, or even lights on, my car looses power. the battery that i had on there was about 6 years old, so i got a new one, i thought that was the broblem, but still same thing. i checked my alternator, and it works. it feels like it looses electricity, i try to accelerate but no effect. i dont know if it is my fuel, electric, or intercooler going bad. i got stock intercooler and stock pipes on 17psi. thank you for your help
Haven't heard of that problem before. Perhaps the alternator is inefficient and is putting a large load on the engine to produce normal power? It seems far fetched though.
Have you checked your codes?
Check your grounds..if you've got good voltage and the alternator is putting out like its supposed to..Id be willing to be you're losing power through a ground somewhere..
No One Ever Listens To Me
yeah very true...if its hp then i would say check your afm and whatnot..but for electrical power grounds and all the wiring harness clips would be a key..... also FYI when you turn your AC on you lose power anyways...thats normal.....
and um for the record 17psi on stock IC and pipes? is this on stock turbo too? :nono: but thats a whole nother thread!
I'd be willing to bet that there is a ground somewhere that isn't getting good connection or just not connected. I just finished an automotive electrical class through college, and that was one of the things that my group had to fix, one of the other groups disconnected a bunch of ground wires that were all in the same place, and everything went dim. What I'm trying to get at is, check ALL grounds.
Discussion Starter · #11 ·
ok sorry for not making my self clear, i loose electrical power, and i kknow when i turn my ac on i loose power, but not that much, it was good before, and also i do not have a sotck turbo 60-1. thanx
nick
1 - 12 of 12 Posts
