Hey, I'm just wondering if anyone on this forum has any luck with a particular downpipe. Thanks alot.
-Dave
-Dave
sounds like a guy thats never owned one before.mullenc525 said:divorced downpipes are not all the are made up to be. Can you say boost creep? Anyway, the only reason that they make more than ~5 hp more is because it automatically cranks up the boost. Crank up the boost on a standard turboback dp with an MBC and get the same effect, without paying out your ass and having a ridiculously loud car at full boost.
soooo..I shouldn't get a bic ddp because I have an n/a block or should I not worry that much about the amount of boost creep??Johnny Dangerously said:sounds like a guy thats never owned one before.
iw ill admit it makes boost creep...i solved that problem in 20 minutes.
took the dp off, bored the wastegate tube a lil more and now im hitting 15psi@2800rpm
normal driving alone im hitting 6psi shifting at 3k, half ass throttle.
in this downpipe, the entire rpm range is ALOT more responsive.
naw, get a DDP...it has nothing to do with the block86SUPRA7mgte said:soooo..I shouldn't get a bic ddp because I have an n/a block or should I not worry that much about the amount of boost creep??
move to Tx or FLimproved said:I would be really interested in knowing how well a re-routed (back in) divorced downpipe works. Larry A was correct, when he mentioned the legal aspects of having the regular DDP in California. Any idea.?
