I have heard mixed things regarding the suitability of carbon clutches for street driving. Carbonetics said they work very well and are easy to use because of the lower friction coefficient when compared to metallic disks. A tech at Exedy USA said the D-core and their SB Series are not at all suited for street driving because the friction coefficient varies significantly based on temperature, and when cold the torque capacity can drop by as much as 30%. He also said that engine heat will not warm the disk(s) up to their ideal operating temp range; friction is the only way to. Tilton USA said carbon/metal clutches are horrible and behave much differently than carbon/carbon when cold. They said carbon/carbon clutches are streetable and the torque capacity doesn’t vary nearly as much.
Since these opinions vary significantly, I want to see if anyone has had experience that supports any of them.
