1 - 3 of 3 Posts
SC Under Pressure
Wanted to give my props to a terrific fuel injector cleaning/test/balance shop. Witchhunter Performance / Injector Services in Washington did an excellent job with my injectors and does so at a considerably better deal than the big name shops using the same high end equipment. The turn around time was 48 hours. I was easily able to contact Gordon by email and phone.
www.witchhunter.com
Not knowing my injectors history, I wanted to have them cleaned and tested before install. They were in good shape, however, all of them showed improvement and the injector balance is now within 0.7% of each other vs. 4.3% before cleaning.
See attached Spec sheet before and after:
awesome! Good info. Just got off the phone with the guys, I am sending my 720cc injectors to them today before I do the full fuel install.
2jz powered
I had my injectors cleaned by them as well. Very fast turn around and sure beats $25 per injector RC Engineering is charging.
1 - 3 of 3 Posts
