1 - 7 of 7 Posts
Hello guys. Just finished my Turbo setup on my Ge, but turbo is not connected. Problem : Car start fine, but a lot of black smoke, smell gazoline. Before i start doing my mods, car was running great. I did :
Iacv remove (Connector still free)
Exhaust temperature sensor is free (Not in the new downpipes)
Knock sensor not connected
Tps suppose to work fine
02 sensor are free, don't work in the new downpipes.
No revolution problem. Idle at 1000rpm after adjusting the new throttle
When i drive, there is no power at all, look like im riding on a death cow...
Still have the cat.
Picture and video. Picture of the black cloud is direct after the video.
Why did you remove the knock sensors, iacv, ? What computer are you running?
Assuming you have a stock ecu you need to hook everything back up. O2 sensor, knock sensors, idk if the egt sensor matters. Once you hook everything up again then see if it still runs poorly. If you changed the injectors then you need to have it tuned with a safc.
From the land down under
What map sensor are you using and is it plugged in/working?
You dont need the exhaust temp sensor to be plugged in for the car to run fine, but as above, I would definitely plug back in the knock sensor.
Yes, I figured that an unplugged map sensor would be the case.
So its running properly now?
1 - 7 of 7 Posts
