Hello, I need help from you supra folks. Does anyone have an axle laying around? I need some measurements to see if it can clear the hubs on my mr2.
Plan:
Use supra spindle to extend it from the hub to allow space for the drum brakes. The mr2 lacks a real hand brake and hinders the chances of putting any BBK.
Issues:
-Supra MKIV axle seems to be too wide to fit on the mr2 hub
-Supra MKIII axle comes with abs ring? For the future when I install ABS on mine
Setup:
Mr2 Rear hub + Bearing
Supra MKIV knuckle/spindle
Supra MKIII/MR2 MKII axle hybrid
Also if there is interest i can try designing a bbk for the mkIII if i can get some measurements of the hub
Plan:
Issues:
Setup:
