1 - 20 of 178 Posts
https://www.autoguide.com/manufacturer/toyota/2020-toyota-supra-review
The Supra name isn’t supposed to be taken lightly — it’s supposed to be the flagship Toyota performance machine. Yet for many on the outside looking in, it seems like the Japanese automaker has outsourced its sports car to BMW. Yes, the Supra was co-developed with the BMW Z4, and it utilizes mostly BMW parts, including one of the most important parts of all, the engine.
But after sending the new Supra around Summit Point Motorsports Park with an almost unlimited number of laps, one thing is clear: this is a fantastic sports car and one that lives up to the high standard set by hardcore fans, enthusiasts, and gearheads. Anyone concerned that a Toyota Supra can’t be made from German ingredients has to get some seat time in this car because it’s impressive just how capable the new rear-wheel-drive coupe is.
Sizing it Up
To start, the Supra is tiny. It’s just about six inches longer in overall length when compared to Toyota’s 86 (also known as the Subaru BRZ), yet it features a shorter wheelbase, a wider track, and is 0.3 inches taller. It looks like true a sports car, too, with its long hood, short deck, wide hips, and exaggerated fender flares. Because it’s a pure-bred sports car, there are no rear seats and there’s a significant amount of reinforcements throughout the chassis to ensure the car is stiff and responsive. Toyota set out to make a car that is more rigid than the 86, and managed that feat by 2.3 times, getting closer to the carbon fiber supercar wonder that is the Lexus LFA.
That’s impressive considering there is no carbon fiber in the Supra. The doors and hood are made with aluminum to help keep weight down, but it’s still a bit heavy at just around 3,400 lbs. For reference, the ideal sports car is probably the Porsche Cayman (in fact, Toyota benchmarked the Cayman S during its development) and that weighs about 3,050 lbs. Other sports car enthusiasts might bring up the base Chevrolet Corvette, which is also lighter than the Supra, as is the ancient Nissan 370Z, but other mid-range-priced sports cars like the Chevy Camaro and Ford Mustang are heavier (although those have four seats).
Under the Hood
On paper, the Supra isn’t going to wow you. The turbocharged inline-six cylinder engine (a BMW staple) makes 335 hp and 365 lb-ft of torque, sending all that power to the rear wheels through an eight-speed automatic. The numbers don’t seem very high in the world of 500-hp cars, but trust me: The Supra is fast. It gets to highway speeds in 4.1 seconds, a fast sprint to be sure thanks to a launch control function. And like many BMWs, the exhaust crackles and burps when you let off the throttle. The responsiveness of the drivetrain is excellent, but you can’t help but wonder what life would be like if there was a manual Supra available. The automatic is a ZF unit, though, which is also known as the benchmark in automatic transmissions.
The Supra features a fancy active differential to help keep that power going to where it is most needed by adjusting the lock-up from zero to 100 percent. And then there’s the incredible amount of grip afforded by the Michelin Pilot Sport Plus tires. The Supra sticks to the road, which was an issue with the 86.
The steering is a bit on the light side, which seems like the complete opposite from what is usually found on German-made sports cars, but the Supra is extremely agile and adept at quick transitions. It has an adaptive and adjustable suspension, which means that it’s always working to deliver an engaging ride and can be tweaked by the driver to provide more feel and different driving experience if needed.
On the Track
There are two important things that happen when you take the Supra around a truncated setup of the Shenandoah Circuit at Summit Point Motorsport Park: First, you have a lot of fun at every corner and second, you pick up a lot of speed at every straight. Follow the pro’s line and guidance and the Supra is a sharp tool that can carve up the track. It’s so good at reading your inputs and making them happen on the road. While some sports cars are so fast, twitchy, and so stiff that they require nerves of steel to confidently pilot around the track, the Supra was happy to go at your pace, letting you build up the experience necessary to get faster around the track. Better yet, the car feels balanced and rotates easily through the corners (or even slide if you want it to) before understeering. Switching through the standard and sport mode sees some significant changes in the way the transmission and engine exhaust note behave, as well as how the stability and traction control systems intervene.
See Also: 2020 Toyota Supra Prototype First Drive Impressions
In case it’s not clear yet, the Supra is a blast on the track, and if you were wondering how the Toyota feels in comparison to a BMW, well I haven’t driven the related Z4 on track yet, but very few BMW M vehicles feel this confidence-inspiring and fun-to-drive on the track. The Supra truly feels like a big brother to the happy-go-lucky 86 in regards to how it drives on the track. It’s both a very capable car and an eager learning tool, helping you get better on the track with each lap and having fun in the process. Brakes were fading on the test cars, but that can be chalked up to the hard laps on the track by a bunch of eager journalists. With four-piston Brembo brakes up front, and a single piston floating caliper for the rears, the Supra features a similar setup to the Cayman S, yet the Toyota is heavier, which could lead to this braking discrepancy.
Simply put, the Supra feels like what would happen if a Porsche Cayman was front-engined. Seeing as the Cayman is pretty much the benchmark for sports car purity, that’s a huge achievement.
Step Inside
It may not be as important to bring up, but the interior of the Supra is a mix of familiar BMW parts with a Toyota-esque covering. The switchgear and materials are all BMW, including the infotainment system, but that comes with a few added benefits as well like the nice digital dashboard, available head-up display, and available wireless Apple CarPlay support.
See Also: 10 Unlikely New Vehicles with More Power than the 2020 Toyota Supra
The cabin is a little tight too — I had some issues fitting with my helmet. Interestingly, the Supra is a coupe that features a hatchback-style liftgate, although the trunk opening is slim and awkward. It might be difficult for buyers to stuff their golf bags in the Supra, but because there’s no divider between the trunk space and the cabin, you can just throw your stuff into the trunk from the seats. And as sporty as the Supra is, it feels fine off the track as well, with a smooth ride and supportive seats to let you enjoy the longer trips.
Pricing and Features
OK, so that’s not what most sports car buyers needed to know, but the Supra has a number of features that push its appeal beyond the enthusiasts. Safety features like forward collision warning, automatic emergency braking, and lane departure warning are among the standard driver’s aids, while you can also get adaptive cruise control, blind spot monitoring, parking sensors, and rear cross traffic alert with an additional package. The vehicle has a base price of $50,920 including destination, while buyers can get a Premium model for $54,920. There’s also a limited run of a Launch Edition model for $56,180, which gets a special look for the interior and exterior. All cars come with the same engine and output as well as the other sporting essentials like the adaptive dampers and active differential.
The price point of the Supra is interesting in how it compares to what Toyota deems its true competition, the Porsche Cayman S. While the Supra feels as much fun, sharp, and balanced as the Porsche, it’s much more affordable (almost $10,000 separate the two) begging the question: are they the same buyers? Porsche buyers will want something more premium and get it with the Cayman. The Supra is also much more expensive (and a bazillion times more modern) than say a Nissan 370Z and has way less power. A base Corvette costs about the same as a Supra, but base models are far less sporty than this Supra, while better-equipped Chevys will be more expensive. Finally, the Supra feels far more of a sports car than the Pony car duo of the Mustang and Camaro, although those two cover a much broader range of performance and price. Has Toyota made a car for a very small sliver of the sports car market?
The Verdict: 2020 Toyota Supra Review
Market strategy aside, the Toyota Supra is fun, fast and unique, even if it uses a lot of BMW parts. Past Supras gained a legendary following not just due to their performance, but because they featured overbuilt Toyota engines that made them a dream with tuners and the aftermarket community. Time will tell if the new Supra will gain this following, but so far the aftermarket shops are all very interested. And while that’s being all sorted out, buyers who don’t have any desire to modify their sports car will be very happy with this new Supra.
Watch the "2020 Toyota Supra – Is It More Than Just A Z4 Coupe?" video. It's a very good review. Objective.
You can drive with the reviewer and see that is feels like a BMW. Even he says it.
I watched the entire video and i was disappointed. The reason why I was disappointed was because all of the cut aways were that of a red car while he's driving a black car so pretty much every single cut away is a fake or stolen or public video this whole fake thing is really getting on my last nerve I fear. He seems like he's never driven a Supra of any type prior to this or at least that's what I got out of it. He doesn't seem to be fully aware as to what the Z4 coupe is capable of yet he titles it "Is it more then a Z4 Coupe" so if he admits that he has not driven the 6 cylinder Z4 how can you possibly be objective to answer the question or title of his video?
And there are multiple things he's wrong about, I'm not even crazy about the Supra MKV and i know these things... Example: He said tan interior (WTF?) and then he said something about black calipers??
I mean how do you possibly get this so wrong, it's on the fricken website: https://www.toyota.com/upcoming-vehicles/gr-supra/
And then at some point's he's comparing it to the 86 which I'd hope it's better then the 86 how is this comparison helping anybody? I guess he's just a car reviewer for non-enthusiasts...
The video that came out today that you need to be watching though is the following:
Administrator
All those youtubers worked off a similar script. Flogging a car around a track is fun no matter what especially when it's free. No doubt the car performs decent, just should not be called a supra. Why is this so hard?
Super Moderator
Because too many people are new to the scene, and simply do not have the experience with a MK4 to understand just how exceptional it is. Your average CarMcToober has never really driven a MK4.
And when Toyota's footing the bill and paying those 'influencers' a shitload of money to generate favorable content, it's obvious what we're going to see.
I'm actually uber sad when Albon said it's better then the MKIV in every way in his video, a part of me died :`(
Very Senior Member
That is like saying today's cars are better than those of 1992 - but just slightly. That is not good.
The car is not better than what should be it's competitors today. It is better than cars about 2 steps below what a MKV should be. Compare that to the fun times on the 1990's when the MKIV ruled.
Holy shit doug got it right, what he says about the Supra and where they missed is Spot On....
Points Made:
- You've neutrared the B58 Motor so why again do you need an automatic transmission to shift faster etc. ?
- In a world where the NSX and the GTR are up there with McLaren's and Ferraris this is where the Supra is? What?
I'll have to rewatch it again but what can I say Doug got it, lol.... :biggrin:
Funny thing is to me all these same script reviews and videos trying to oppose the hate for the BMW is damage control from Toyota. They are in a justify what they did mode. I'm very surprised that from their USDM market study they didn't see this coming. Or maybe they did and just calculated the other countries and markets acceptance of the car will make up for it.
  • Like
Reactions: SupraApe
Wheel Whore
Doug Demuro's review was very fair and unbiased on the new Supra.
I found it interesting that he says around the 3:30 mark that "I pay for my own flights to keep my objectivity" as it seems that Toyota has targeted popular car Youtuber's and gave them a check to hype the car better than it is.
But this is just hearsay.
I don't agree with him on the BMW engine part. Even though BMW has made good engines for its M series cars Toyota has made great engines too. If someone wanted a BMW powered car wouldn't they just buy a BMW? No one buys a Chevrolet Camaro to find a Ford Coyote Engine and Chassis Underneath.
1 - 20 of 178 Posts
