1 - 15 of 15 Posts
Discussion Starter #6
Thanks everyone. The trans is a BoostLogic Toyota auto with a 3800 PI convertor. I have a 76mm p-trim, Greddy header and wastegate, HKS 272 cams, 1000cc injectors,AEM,Sound Performance intake, 9" Ford rear with 3.89 gears, and an Alston 4-link with coil overs. At 18 psi it made 500 at the wheels. I'm currently running 20 psi until I can line up my tuner for more boost. I was able to launch with about 6 psi so it wasn't too doggy on the launch. The line lock is not hooked up to a switch yet so I didn't do a burnout , but , it seemed to hook pretty good. The tires are 275/50/15 MT dr's. Without me in the car it weighed 2480 lbs. You can see the motor and a dyno run by searching Supra MG on youtube.com I got the cage certified a few days ago, but still have a few things to do before I can get to the track. I'm pretty confident it will run mid to high 130's the way it sits.
Nice.. Curious why you didn't go with a TH400? Looks like you are ready to put down some real power. I'm putting in a TH400 in mine right now with a transbrake and a PT 3800 converter..
I like it though. What year is the MG?
With that setup at that weight I would look for more mph then that at decent boost levels.
Very cool!
Discussion Starter #9
(Nice.. Curious why you didn't go with a TH400? Looks like you are ready to put down some real power. I'm putting in a TH400 in mine right now with a transbrake and a PT 3800 converter..
I like it though. What year is the MG?)
I stayed with the Toyota auto because I plan to drive it quite a bit and wanted the overdrive. Also, the adapter for that swap is way out of whack, I was quoted more for the adapter ($2000) than what the BL auto cost($1800). My Supra had the BL auto, ran a 10.37, and performed flawlessly all of the time I had it. The car is a 1966 MG MGB GT.
Are you saying you're putting a 2JZ in an Mg also? I thought I was the only one with a mental problem:)
(With that setup at that weight I would look for more mph then that at decent boost levels.)
Haven't had it to the track yet, I'm just doing an educated guess on the mph.
HIGH OFF BOOST
Congrats Steve. Amazing car!
Nice work!
Why is it that people insist on putting their hands on/pushing cars that are doing a burnout? I never understand that.
Anyhoo, nice work!
1 - 15 of 15 Posts
