1 - 4 of 4 Posts
So i recently changed from my stock sz shocks to some oem bilsteins since they were bottoming out. But now i have a rattle sound in the rear passenger side over any slight bump and it squeaks over bigger bumps in the rear. The shocks themselves aren't leaking what could be a cause of this issue? I only recently bought my car and am rather new here
Are you certain that they were tightened up fully when they were installed? Might be something as simple as a loose bolt or nut.
I cant be 100% sure but should i get a wheel alignment and tell them to also to check all the bolts and torque them down if needed? Also it sqeuaks over bumps could that also be due to a loose bolt or is that because the springs are worn?
1 - 4 of 4 Posts
