1 - 2 of 2 Posts
i cant get my search button to work right all it does is come to a blank page.
anyways im picking up to supras within 2 weeks one is a spd turbo and one is a 5 spd na. the turbo has body issues but the na doesnt na has no motor and 5 speed has a good motor bad ecu. what would it take to swap the motor fromt he turbo to the na how straight forward or not so straight forword woiuld it be i know the wiring harness but what else is involved. would it be cheapier to just have the turbo supra repaint and rust spots removed
Chasing Leaks 24/7
you'll probably want the tranny and rear diff from the turbo too, and to get a turbo ECU or go AEM. I believe everything is essentially the same with the bodies. You might look into whether either or both cars are ABS or not, cause that adds more work to do if the Turbo is and the NA isn't.
Anyone else have anything to add?
1 - 2 of 2 Posts
