hey guys, im hoping that i can get some insight on this whole thing.
so i have my 1989 supra, that i already have a 1jz sitting in, but my wiring harness was shit, so i bought a brand new usdm 2jzgte harness.
now i pretty much need the usdm 2jzgte pinouts on what body plug wires to hook up to which ones on my 89. my 89 IS A 1989 WITH THE SQUARE MOTOR MOUNTS ,
i know its the transition year n this is whats got me confused on the body plugs. fyi. so ive already got the 550s and 2jz map sensor . and resistor pack for the 550s.
all i need to do is wire in the harness , my problem is what wire from the maf off the usdm harness do i connect to the air temp sensor on the jz intake manifold?
2nd question is what wires off the 2j harness connect to which body plugs on the car, and i have looked all over, but all i can get is a pin out for the aristo jdm 2jz into a mk3.
and i also have a jdm 2jzgte ecu running the whole thing, so i will be running map based only, and im trying to get around the air temp sensor, and hooking up the body plugs pls help, and thank you if you can.
i know somewhat what im doing but i still need some help if any one could give me hands on help that would be even better i live in baldwin park, ca.
if any one need more clarification on what im doing pls let me know i will be happy to explain, as what i have wrote i tried to explain what im trying to do. so if confused pls ask, im lost too lol. thanks for the help in advance.
