I really doubt it, the TT 6 speeds ring gear is 220mm, I believe the NA (and the Automatic TT) use a 200mm gear. Bearings and carrier would also be different.$upraMan said:Does anyone know if the N/A casing can be used with TT gears? Is it a "simple" swap - take N/A non-LSD out and put TT LSD in?
Thanks!
Thanks for the info. I've actually put the TRD diff in my car. TRD sells the gears only, so I have to keep the stock casing. Now there is a guy w/ N/A Supra who wants to buy my stock TT LSD gears, but is concerned whether or not he can use them.Lagtime said:
You would be better off swapping the whole 3rd member.
Why do you want to do this?
