1 - 20 of 20 Posts
I got an idea to switch from OBDI to OBDII. It's not performance related.
There are a few gadgets for only OBDII cars like the Pocketlogger and CarSpy.
I want to know if it's possible, and if there any problems associated with it except the OBDII simulator.
i guess it can be done but you will also need a new engine harness i belive and some other nick nacks.
Defender of the Universe
I would just get the aem and log all the data you want, not to mention the ability to tune your single alot better
Old School
Plug and play.
AEM doesn't make 2 different versions of their standalone for OBDI & OBDII Supras, do they? ;)
Your only issue will be the "Check Engine" light from the 2nd O2 sensor, you'll need an O2 simulator.
Lagtime said:
Plug and play.
i know aem doesnt make 2 different versions, but i was assuming the only reason he wanted to go obdii was to datalog, and with the aem you can do plenty of that :)
The problem with what you're trying to do is the OBD1/2 DLC connectors are different. So even if you install an OBD2 ecu you still will not have the proper interface connector to plug in devices like pocketlogger,obd2meter, etc.
alright, it was just a thought.
As for the AEM, I refuse to go with it. I am not a serious autox or drag racer.
I will try the OBDI pocketlogger to see if works with the Supra OBD interface. Otherwise I'll just stick with the Techtom unit.
Thanks for the answers, if there are more points to consider, feel free to post them.
I am not a serious auto-x or drag racer either yet I use an AEM? If you are hardcore enough to want to datalog, you are hardcore enough to get an AEM.
Just my opinion, of course.
-m
Are you also using a OBD2 data logger
QUOTE]Originally posted by SupraGator
I went from a OBD I to OBD II and everything is working fine. [/QUOTE]
what if anything else did you have to change the ecu and what else (good info for the tech area)
« f ï z z | ë »
i thought obd2 had a bunch of extra sensors that obd1 didn't have. so all that's needed to keep the check engine light from coming on is the o2 simulator?:confused:
« f ï z z | ë »
i thought this would be a simple question for the more knowledgable heads in the forums. yes/no/not sure?
As far as I know the sensors are pretty much the same. OBD2 just monitors a lot more parameters. Installing the o2 simulator cured my check engine light and my car is running great. Stay tuned though, some people like Sol have been having some rich idle problems after switching to OBD2.
« f ï z z | ë »
thanks toyotafan.
SupraSol, please updated us/me on what happens after you've wired it in. pm me if you would rather not post it up. thanks.
will definitely let you know in here, I have nothing to hide, really hoping I can get the OBDII working.....otherwise the AFC is pretty useless between 5-6K rpm.
thanks toyotafan.
1 - 20 of 20 Posts
