Hi there,
I bought 1-2 Syncrotech Sleeves and they are not the same as the OEM, should I install them anyway?
There´s some squares that will be missing that goes in the middle...
Yeah, I'm not sure I would use those (although there was a revision so perhaps you have revision A and are comparing to revision b?). You should look into contacting suprasport about their sleeves
Thanks for the help, I sent them a message to see if I could use that one...
The silver one is Syncrotech the golden one is OEM, they fit on the same position but they are not the same, the company still didn´t answer about it.. I´ll keep you guys posted.
Discussion Starter · #6 · (Edited)
It seems mine are type A one of the first ones that came out on V160. Considering the fact that it was made on 10/1993 it should already be type "B"
