1 - 20 of 33 Posts
daredevil racecar builder
That looks to be really well done, any idea when you'll have it done? I'm not sure how it will look for your paintcode. I think it would look pretty awesome on a nice black or white car.
It looks great so far, way to be different! :)
Job well done get some pics up when you have it all sanded down and primered, it looks amazing good job.
3M ENGINEER R.&.D
Maybe another month to finish the welding and a week at the body shop. Also looking for sponsorship to have it molded;)
1.5JZ Turbo Supra
how did you start this thing...
step one.. cut... thats how you start.. obviously after some planning on how you want it to look
25psi Bliss
Looks great, and this is definitely a purposeful mod'. I'll add another slit / vent by the radiator. Comparable to the exh. manifold & turbo, the radiator will be the next significant source of heat within the engine bay.
3M ENGINEER R.&.D
Discussion Starter · #13 · (Edited)
I'm thinking adding a slight vent opening by the radiator area instead of the small vent at the upper corner (I'll look at it again tom)....what say you?
25psi Bliss
Anything that allows for heat evacuation from the primary sources will be a step in the right direction.
Note, at speeds the hood will be a high pressure zone. So, a little bump at the leading edge of the 1st slot will create a lower pressure area, thus aiding in slightly better evacuation in all the remaining slots. Little picky fluid dynamics there, but either case, as it stands presently, your modification is a "damn" good idea.
1 - 20 of 33 Posts
