1 - 4 of 4 Posts
I just bought a ‘91 mk3 Supra with a 7m-GTE. The car has a hesitation and starts to backfire once it get into boost not allowing the car to accelerate. But the car had also been converted to a manual r154 from the automatic, and it still had the automatic ECU in it. It has a t61 turbo upgrade and a newly rebuilt engine. It seems to be running fine other than the hesitation. Would this be a tuning issue or an issue with the transmission ECU?
I turn my own wrenches!
I doubt it’s the ecu causing the issue as at most it would be shift timing, idle rpm, but should not cause a “hesitation”. I would look at the tuning side of things like fuel cut, spark equipment/setup?
Does it happen if you roll slowly onto boost vs stab on the throttle???
Sounds like a lean spot on tip in causing it to misfire, could easily be verified with a log-able wideband.
1 - 4 of 4 Posts
