T
traxon
·Guest
I just GTeched my supra at low boost w/pump gas because I was curious how it compared to my car when it was BPU. As you can see, it's quite a bit faster, even at the same psi. Remember this is only 18-22psi, not 33, huge difference. I will GTech again at 33psi once I get some new plugs.
RPS single kit w/t61 .7 (go to supratwinturbo.com for exact mods I have so far):
Conditions: 87 degrees, moderately humid, very fouled spark plugs (wouldn't go past 21-22psi, should go past 33psi), fuel system running extremely rich
(plugs turned black within 1500 miles)
1st gear: .74 g's @ 18psi
2nd gear: .67 g's @ 21psi
3rd gear: .51 g's @ 22psi
4th gear: .38 g's @ 22psi
5th gear: .23 g's @ 20psi
6th gear: .18 g's @ 20psi
1/4 mile: 11.05 sec
0-60 mph: 4.2 sec
Compare this data to the following. Keep in mind these aren't ideal comparisons because of the vast differences in temperature and humidy.
BPU:
Conditions: Very cold and dry (maybe 20-30 degrees, I don't remember exactly, fuel system running moderately rich
1st gear: 0.53 g's @16psi (no traction)
2nd gear: 0.56 g's
@ 18psi
3rd gear: 0.4 g's
@ 20psi
4th gear: 0.31 g's
@22psi
5th gear: 0.21 g's
@22psi
6th gear: 0.16 g's
@22psi
1/4 mile: 11.8 sec
0-60 mph: 4.6 sec
1/4 mile: 11.05 sec
0-60 mph: 4.2 sec
BPU:
2nd gear: 0.56 g's
@ 18psi
3rd gear: 0.4 g's
@ 20psi
4th gear: 0.31 g's
@22psi
5th gear: 0.21 g's
@22psi
6th gear: 0.16 g's
@22psi
1/4 mile: 11.8 sec
0-60 mph: 4.6 sec
