I recently bought this 94 supra. It has a VPC/GCC and according to the wideband I put in it, it is off the charts rich under boost so I took it to the dyno to try and tune it. Plus I wanted a starting point before I start modifying it.
Dyno run was made with a mix of 91 and 101 octane because I was going to turn the boost up on the dyno. Boost was at 1.3bar for these pulls. The graph shows 3rd gear only. In first gear the car is rather lean while the boost builds and the fuel pressure regulator waits for the boost to raise the fuel pressure. For that reason I was unable to lean out 3rd gear anymore because I didn't want to cause more problems for 1st gear.
The first pull was off the street, last pull is after tuning with the GCC. I was hoping for higher numbers at 1.3bar but this is my starting point. I plan to have boost logic build the tranny very soon along with a 3800 stall.
Here is a rundown of the car:
Turbo System
WOTM race header, Tial wastegate, Turbonetics T72, HKS large FMIC
Stock 2JZ-GTE motor, compression 154-157 psi
Titan Motorsports Billet Adjustable Cam Gears
HKS VPC/GCC piggy back
Boost Logic Billet Crank Dampener Pulley
WOTM Fuel System with 750cc injectors
4" HKS Titanium Cat-back Exhaust, WOTM 4inch DP and midpipe
Stock Toyota Automatic, stock converter
Turbo System
