1 - 20 of 87 Posts
SUPRAS FOR LIFE
fast cars....but wats up with the shift by the supra dude in the second race......nice clear video...
Yes, stock bottom end, RS4 cams, k04 hybrids, and pretty much other standard bolt-on stuff. A couple psi, well, i was spiking 24 lbs on the second run, so yea, a couple more. Plus it's not quite boosting right in 2nd gear, as we just put in a new EBC the day before and are working out the kinks.
custom tuned AWE (GIAC) sw then tweaked with an AVC-R for higher boost and a custom MAP sensor to fight throttle cut. It all seems to work pretty well together. Not sure how much more we can push the motor though. GT28's are on their way, so we'll see....:)
Sorry, but there is something wrong on the Supra.
There is no way that an Audi S4 with only K04 turbo to beat that Supra with at least 580hp/crank.
The max power with K04 turbos is around 520/crank.
I had raced a couple of S4´s with that setup at only BPU and had won.
There was nothing wrong with the Supra. He traps mid to high 120's on that same set-up. I stayed about dead even with an EVO II later that night that trapped 128ish at Norwalk the day before. I'm not running standard K04's.
1 - 20 of 87 Posts
