1 - 2 of 2 Posts
On my Greddy T78 turbo the oil supply flange is pointing the same way as the compressor. I can loosen the turbine and rotate the shaft but cannot point the supply in the opposite direction. Therefore with my turbo mounted the drain is at the top and the feed is at the bottom. Is there a way to fix this??
Maybe I'm reading it wrong, but it sounds like your supply line is on the bottom and drain at the top. If thats the case then loosen the bolts on the compressor housing and exhaust housing and then rotate them 180 degrees so the drain is on the bottom.
1 - 2 of 2 Posts
