1 - 11 of 11 Posts
Is there any difference of these 2 MONSTER Turbos?
ADVANTAGE & Disadvantages, if any???
ALSO,
What does the 1993 - 1998 (or 2002) fully stock Supra TT 6-Spd/4-Spd Auto run on Boost (PSi)???
I would REALLY like to know these things. Even though I already know SOOO MUCH on this car, I always let the "simple" things pass me by.
Thanks & Cheers,
Miller
FUCK JDM
ALSO,
Thanks & Cheers,
Miller
Judging from how you post, you obviously " Dont know to much " first off ,
T88/T88H isnt a Monster turbo, 2nd You shouldnt post how much You know and then ask a question and in return expect answers, you wont make it far on this forum :hay: and will get bashed, 3rd 10-11psi stock
Vendor
Thanks & Cheers,
Miller
Both T88 34D turbos use the same compressor wheel which is a 70mm inducer, are journal bearing and very reliable. They produce good horsepower but the H is rather lazy due to the fact that it's Turbine is almost as large as a GT47. The normal T88's turbine is slightly larger than a GT42 (aka PTE GT-S).
There is also a T88H-38GK which uses the same large turbine wheel as the T88H but instead of the normal T88 34D 70mm wheel it uses a larger 76mm compressor wheel better suited to its large turbine.
Furthermore there is a T88 33D which uses the 66mm compressor wheel found on 99 percent of the T78 cars in the US however it uses the same GT42 sized turbine.
So would the 38GK produce comprable numbers to a 42-76?
Boost Junkie
Miller,
Read the FAQ in this forum and visit www.mkiv.com. These sites will help you gain knowledge on the Supra.
Steve
Discussion Starter #6
I mean MONSTER by the size. I wouldn't call it "petit". As for asking a question, I am ALWAYS curious. It would be REALLY stupid to say I KNOW EVERYTING. When in fact, nobody here (or anywhere) can know everything. Unless your Jay Leno!
But being 82, I'm sure you know just enough. :)
Dont worry about it Miller:) I'm curious about the older Greddy turbos too!:wavey:
Vendor
T88 YOU
a t88h 34d should produce a max power of about 950rwhp, the 38gk should support about 1050rwhp. they are almost as laggy as a t6 turbo but wont make near the power, however for the price greddys are reasonable and the mitsubishi turbos they use will never fail.
Vendor
But with a penalty in spool correct?
Yes, it should be slightly more responsive than a GT4708 (47-80).
I agree with the above that it's a '1050ish' turbo in the right conditions. Definitely the most power you're going to get from a 'readily available' shelf 76mm turbo.
1 - 11 of 11 Posts
