1 - 3 of 3 Posts
Hey fellas, my tailight lamp failure box keeps shorting out. At first I thought it was a wireing shortage... but recently I found alot of water leaking from the left tailight, which is where the failure box is. My weather strips for my hatch is also in bad condition. Did anyone else have this problem with the leak. What should I get replace and how much is it? Thanks. ...... Happy Spooling!!!!!
The Great Kruso
THe problem is with the gasket that goes around your tail lights...replace that and the problem will go away. As far as your current problem, take all the bulbs out and throughly clean out the bulb holders and you will be good to go. BTW that is a VERY common problem with our cars.
Kruso
Don't forget your blinker fluid. You could fuse your headlamp bearings if you don't fill 'em up. Check at your local autopart shop, they should have plenty in stock.
1 - 3 of 3 Posts
