Moderator
Hey guys, one of my driver's side taillight bulb (nearest the backup lamp) keeps on burning out. The bulb originally burned out yesterday, I replaced it today and it burned out about 5 minutes later. I've had the car for awhile now, and it just started doing this.
Thanks in advance
Is the filament in the bulb broken, or is the entire glass coated with a silver layer, which you can't see inside of the bulb?
Stan
Moderator
The filament broke on the first one I took out. I haven't replace the one that I put in earlier today because it's raining right now. A fresh bulb shouldn't burn out *that* quick unless there is a problem IMO.
If the filament broke, the usual cause is due to excessive vibration or shock.
If the entire bulb is coated with a shiny silver layer inside, this is usually caused by a voltage spike that is much greater than 13.6V.
I found this info on PIAAs Japan website.
Stan
Moderator
Thanks for the reply. I don't think the bulb has been subjected to either. The other taillight bulbs are fine. I don't wanna fry another bulb until I can pinpoint the problem.
Anybody else have ideas?
Please keep in mind, the voltage spike can be caused by the following:
Having your lights on BEFORE you start the car.
I doubt there is a particular brand that will work better than the other.
I would assume there is no water in your tail light lens, so I am stumped.
Stan
