1 - 16 of 16 Posts
hey i need some more ideas on getting rid of unused crap under the hood like cruse control an other stuff like that.
How are you venting the fuel system with the canister out? Just wondering, I removed one and closed looped the system but someone told me I would have lock problems.
The ac compressor will work for vaccuum bagging composite parts.
Throw the cruise control in the trash.
ridah are your lines venting into the engine or are they closed off? I've heard that venting into engine bay is fine, cause it's being vented, but if they're closed then a vented gas cap is needed to give the gas fumes somewhere to go on a hot day. You probably knew that already though.
white guy
hmm, you can do these:
Remove, and block off EGR
Remove, and block off charcoal canister
Remove AC
Remove powersteering (and convert to Mustang Steering Rack)
Remove belt driven fan and replace with Electric fans
Just some ideas for making more space in the engine bay... and I always wondered if someone ever put an electric waterpump on a 7MGTE, and if it's a good or bad idea.. that'd free up alot of space, as well as some throttle response.
Discussion Starter · #12 ·
thanks for all the ideas .....in the next few weeks all that stuff is goingin the trash thanks again... Adam....
Do You Even HKS, Bro?!?
I took out my TEMS when I went with my KYB Susp. Wires and harness is still there. I removed the actuators, console switch, and the Comp in the rear.
Dr Wheelspin Rh.D.
There are not enough vapors coming out of the gas tank through the charcoal canister line to ignite or even smell. I've had mine open to the engine bay for years with no problems.
I removed TEMS, minor weight savings, huge money savings ;)
1 - 16 of 16 Posts
