1 - 19 of 19 Posts
When I drive sometimes my passenger frnt comes loose, I don't know if it's from the frame twisting or what, but I tighten it but don't want to strip it.
BlackWindEXE said:
when i try to put my targa back on, the driver's side doesn't come set in like it should so i cant even screw it back. when i drive it just bobbles up and down and i know i shouldnt drive like that. any help? ill post pics if i have to
Not sure what you're saying. "Come set in" ?
sean
Suprachik8 said:
my weather stripping around my targa needs to get replaced coz everytime i wash my car, water leaks thru :(
Where precisely are you leaking at? There are several spots that water begins it's entrance....so there are different fixes/locations of fixes.
:stickpoke But we don't drive BMW's :D
MR2ninja said:
if your targa leaks, there is this BMW manufactured sealant that you can buy. I know a lot of mr2 guys use them on their targas...
The key is to know where to put it. I personally have found that the sticky backing on Dynamat works just perfectly. Not messy and it's very manipulative.
blkturbo!: I'm sure there are other great items one could use as a sealant, such as the one you mentioned.
before getting into drastic measure, try some silicone spray (the 100% kind, nothing with petroleum, which may eat your rubber). if that fails try the next step, which might be what blkturbo mentioned...
I cant imagine how far out of alignment it could be. I have to wiggle mine slightly, but that's just to make sure the threads are biting correctly before I actually start screwing it in. But actual alignment?? Either the body or the targa would have to be far outta whack from what I'm imagining, but I doubt thats the problem....
Then I'd have to say they're stripped in that corner.....need new bolt and/or nut in that corner.
1 - 19 of 19 Posts
