Targa Top Tool
1997 Views 5 Replies 4 Participants Last post by  Jeff Lange
Does anyone know if the MKIV tool to remove the targa top will work on the MKIII's? Thanks in advance
Exact same tool.
just use a 6mm alan key. it should work also.
alan wrench wont work the owner before me stripped them so my only hope is to get the key but i cant find one :(. thanks for the help
You don't need an allen key or the original wrench. Go to the auto parts store and buy a socket that has a 6mm allen key built into it. You then put it on a ratchet and wow! It works!
New tool is under $20.00 from Toyota, just get one if you want one. If you want to use a ratchet that works too.
