'97 -- '98 Turn Signals
I'm in the middle of doing the conversion on my 93.5. The third stud on the new signals can be unscrewed, and not used, should you like. You can also unscrew the thrid stud, temporarily place the new singal, and mark the outline with a marker, as to where the third stud should go. Remove the signal, and drill. Pretty simple.
Now if I could only find the correct harnessing/bulb sockets for the upgrade. Any suggestions? In case you didn't realize, the stock socket and bulbs will not fit the new signal.
Regards,
R. Laws
93.5 Anthracite Metallic
BPU 6-Speed
