·This should be a simple question.
Let's say I have a 2.0L 4 cylinder engine running a small turbo at 12 psi and putting out 150 horses. What happens to the powerband if I get a larger turbo and run it at 12 psi (the same pressure)? Is the engine making the exact same amount of power?
If so, what's the advantage in having a bigger turbo? Just to be able to run higher pressure which the smaller turbo isn't capable of?
Discuss.
Discuss.
