1 - 14 of 14 Posts
Hi all,
I just got my set of coilovers (Tein Comfort Sport) and will be installing them soon. I just wanted to run this by you all for any tips/pointers. I will be following the steps in my repair manual for removal/install of the suspension, since the Tein instructions are in Japanese.
Do I need to get the car realigned after installing the coilovers?? What about corner balancing??
I never aligned the car since I bought it back in 2003, and my car seems to pull a bit to the right when driving.
FYI - My car has 52,XXX miles on it.
Any advice is appreciated.
TIA,
maguirre
I don't know any thing about corner balancing but you will need to get an alignment once you put the coilover in. Any time i have ever installed lowering spring or coilovers i always got an alignment done as that is what i have been told to do from other people including Toyota Techs.
And even if you don't have to, your car pulled before so it's not a bad idea to get the alignment done.
(Rare & Unique)
Install them first and let them sit for about a week.. Get an alignment done definitely. You can get the "Lance" alignment done when your ready as some of the NE guys have done already. Theres a shop around bklyn if youre nearby. pm me for details
on a side note good choice in coils i just installed mine last weekend going to get the alignment done this weekend. quick and simple install.
Thanks guys for tuning in.....
Are there any special tools I need.... perhaps an impact gun for the top nuts???
How many hours will the install take me????
maguirre
i have change mine in about 4 hours (with all the EDFC stuff) Just remember you have to remove the front upper arms top (unbolt the washer tank in the left side to remove the bolt)
Do you guys have or know where I can get a copy of the installation manual in english?? The instructions that came in the box are in japanese. I made inquiries with Tein.com... I waiting for their reply.
I was told that the recommended height (recommended by Tein) for the coilovers is spelled out in the instructions.
What height do you guys recommend??? I know I don't want the car too low that it becomes undrivable.
TIA,
maguirre
Mind if I do a J?
I installed my Tein's with nothing but a socket set. The rears are easy, but the fronts require a little bit more work. After doing one of each, you'll notice little shortcuts you can take. My front driver-side coilover took almost 4 hours and then I did my passenger front, but it took only 45 minutes the second time around.
(Rare & Unique)
The fronts are a lil more involved removing the longer stockers. I had to remove tha A arm with the long bolt, youll see it. As far as height its not a big deal.You can raise the whole set(springs are closer to the top hat) and start to lower to your height preference from there. GL
Mind if I do a J?
Removing the A-arm is unnecessary. That's pretty much the reason why my driver-side took 4 hours and my passenger side took 45 minutes. If you crack that ball joint, the entire A-arm falls down and you can access everything through that. I took my rotor/caliper off and then disconnected my OEM strut from both positions (down on the suspension and up in the engine bay) and then cracked the ball joint on the A-arm and it fell right down. Then I just swapped my new Tein in and I was off.
Oh yeah, and don't forget to loosen that foot-long bolt that the A-arm connects to. It's a mofo, but if you loosen that, the A-arm will fall and it won't be necessary to take it out.
(Rare & Unique)
My bad, i was only referring to the long ass A-arm bolt !!! Not the entire assembly.
Not a bad job at all
when you say "crack" the ball joint. what do you mean exactly and which ball joint?
Mind if I do a J?
By "crack", I mean to simply just disconnect. The ball joint I'm talking about is the one directly behind the top of the brake rotor. It connects the A-arm to the wheel hub assembly I believe.
1 - 14 of 14 Posts
