V-tec JUST KICKED IN!!!
Recently adjusted the Tein flex dampening force from 14- 12 F and 8 - 10 r. The car handles fine but seems to produce a small squeeking sound when compressing. Anyway to fix this or would it go away after a while?
Last stock TT on Earth
The sound might be coming from your solid pillow mounts. If you change the setting back does it go away?
I'll try this, this weekend. sorry I park far away from home. If lets say the sound goes away what does that mean. If it doesn't do I need new mounts from Tein? Thanks for your help.
BLACKOUT
come to think of it , is there a recomended setting for the flex coilovers ? i have mine set at 16 all the way arround and dont see any difference unless i drop it to the lowest setting
^I wouldn't use the highest settings or the lowest settings, usually things like this don't like to be set to their extremes. I just leave mine at 8-9 all the way around.
Discussion Starter #6
Anything above the 16 setting may damage your suspension. 16 is borderline safe. Also I believe japanese coilovers are generally hard to tweek. They are either too hard or too soft. I will definitely be going with a set of Bilsteins next time around. For now I must get rid of this damn squeaking! It's like there's a mouse in the wheel well.
