1 - 14 of 14 Posts
old school poster
i am in the process of installing tein re's in my supra and i noticed that the front coilover only has about 1.5" of travel when you factor in the bumpstop.
im just wondering if this is normal for re's? i know it has a stiff spring rate so it wouldnt compress much anyways but that seems really short
cullen said:
i am in the process of installing tein re's in my supra and i noticed that the front coilover only has about 1.25" of travel when you factor in the bumpstop.
Assuming you've lowered it somewhat, that sounds about right. There isn't much available travel there to begin with before the front tire hits the top of the fender liner, and lowering it uses up some of it.
cullen said:
im not talking about the wheel travel, im talking about theshock travel.
even with the shock at full extension, it has only 1.5" of travel with the bumpstop
The front Supra motion ratio is somewhere in the .52 - .6 range, so if your shock has 1.5" travel that would equate to roughly 2.5" wheel travel. That does sound somewhat limited though. Set the spring as high as possible and use the telescoping feature on the body to adjust height.
old school poster
i am only using the tein bumpstop
i have the spring perches set up high as it will go. i have the shock fully extended. and it still only has a max of 1.5" travel between the spacer and bumpstop
ill just call tein and see what they say.
old school poster
im not sure if you have handled re's or not but they have an extremly high spring rate, dampening rate and very little travel. if i bottom these out then i would be having other problems besides my tires hitting the fender.
the max travel i have now would be 2" i have much more than 2" till my tire hits the inner fender or otherwise.
I haven't run REs, but I have run 1000lbs. springs and still bottomed the tire into the fender with bumpstops that were too short.
My RA's have the same spring rate as the RE and if you have the ride height wrong it will bottom out as Eric describes. Eric and I have a long conversation on the subject with Carl at Thunderhill a little over a year ago. :)
how much travel does the stock suspention supposed to have at stock ride height??
1 - 14 of 14 Posts
