1 - 7 of 7 Posts
Best case scenario is just a blown hg. You may have cracked, or warped your head. Before you replace your hg take your head to a machine shop and they can tell you if it is cracked or warped. Good luck
I think with the coolant redlining, its to the point where you cant drive... You probably warped your block/head, scored your cams/pistons, etc...
Dr. Jeff Lange
If you get a BHG, I'd pretty much stop driving the car and fix it, driving it at all anymore is just making things worse for you.
After you get a BHG, I wouldn't recommend to anyone that you drive the car AT ALL, but if it's just to get it home or something I can see that.
1 - 7 of 7 Posts
