I just finished installing a BL61 kit on my 94 tt. I turned on the car to check for coolant leaks and found a few. The wierd thing was though, my temperature gauge remained baried down the entire time (with the car running for a few minutes) and some coolant/water started to boil over. I then turned off the car and realized that the lower radiator hose was cold. i am trying to figure out why the temp gauge wouldnt go up and why apparently the thermostat didnt open. As i said i just finished a BL61/ greddy 3 row install so did i forget to do something? Is the system not being pressurized due to the leak responsible for the problems? The thermo was fine before so i wouldnt know why it would go bad suddenly. Thanks in advance for your help.
Daniel
Daniel
