1 - 4 of 4 Posts
Jihad Killer
Hey guys i have been sitting here just thinking about my car..
Its been bugging me.........
Here is my issue.....
My temp guage just spikes to the top and wont come down..When i unplug it from the sensor on the engine it falls all the way down and just goes dead....Sooo it is working its just not working the right way.....I know a couple of other guys had the same issue, did anybody ever figure out the issue????
Also my speedo is dead to, it doesnt move at all..Ive taken the cluster out to make shure the speedo cable is plugged in and checked the tranny plug too..
Sooo my question is can the speedo cable brake???
can you use the 7M one or is the 1J different??
Is there a wire i have to check?? It worked for a little while then just stopped one day..
I have the 1J speedo gauge in there btw....If that matters...
Josh
Speedo cables break... there are 2 pieces, so make sure you replace the broken one. You may wanna check on SM, since the search isn't very reliable here... lots of info on broken speedo cables.
The 7M/MKIII speedo cable S/B the same and is what most ppl use in their swaps (unless they had the clip).
1jz-gte motivation
SM= Supramania . com and s/b is should be.
1 - 4 of 4 Posts
