1 - 15 of 15 Posts
I am going to use my wideband to tune a friends car. Can I just mount the o2 sensor at the muffler and still get a accurate result? I just need 2-3 pulls to datalog.
ƒ=1/2π(√k/m)
On a dyno? or on the street?
Either way you'll probably notice the readings to be a tad leaner than those read 12" or so from the turbo's exit.
Innovate sells the clamps you'll need, but probably isn't recommended for street use. ;)
We were going to do it the ghetto man's way and use a empty warehouse street.
MK3Brent said:
Well.
Do you have enough money for a new sensor?
Nope, but he doesn't have a wideband bung. Might just secure it nicely and then take it for a spin. haha.
ƒ=1/2π(√k/m)
Well then bank of ruining the sensor when it goes flying off, then feel lucky when it doesn't! :)
Good luck.
Addicted to oil
I have been told by a professional dyno tuner that the exhaust is .2 - .3 afr leaner at the tail pipe than the downpipe. Just my 2 cents.
Dennis
1JZ BLING!
o2 sensor is ignored at WOT. You are only tuning WOT, so it won't matter. Suck it up and hit the gas. The important information will be displayed.
Discussion Starter · #11 ·
I read a while back that the existing o2 sensor location is too hot and can destroy or distort the readings. Is that true or just a myth?
Definately sounds like a better idea though.
ƒ=1/2π(√k/m)
Is it another MKIII you'll be "tuning" ?
How are you going to adapt a screw in sensor to a bolt on?
If you buy a o2 sensor kit from AutoZone, they come with the adapter. :)
Discussion Starter · #13 · (Edited)
No a celica I'll probably just mount it on the exhaust where the silencer goes.
We need to know that part number from autozone or Napa. Do you have it?
ƒ=1/2π(√k/m)
I found them when trying to get a new o2 sensor.
The sensors were screw in, but came with the adapter plate.
If you go into AutoZone and ask for a o2 sensor for a 89 supra, he'll bring you the box.
I'm sorry I don't have the part number, as I ended up using my old sensor. :(
1 - 15 of 15 Posts
