1 - 4 of 4 Posts
if the shocks are replaced with aftermarket non-TEMS-compatible shocks, what will happen with the TEMS light on the dash? will the lights just go out or what? and is there a computer i should remove too? and any other advice you have for removing TEMS system and installing aftermarket shocks is greatly appreciated. thanks.
so even if i remove the entire system except for the lights in the dash, it will still go to 3 bars under hard cornering, etc.? what all did you remove (hardware) when you got rid of your tems?
1 - 4 of 4 Posts
