1 - 20 of 69 Posts
Most Powerful Supras in Canada
The old list thread was dead and forgotten.:die:
Below you will find the latest list of the most powerful Supras roaming the streets in Canada! The list will be kept up to date with all new and relevant entries.
To be eligible to make this list please provide the following:
- Name
- Generation of Supra
- Motor,Turbo and Transmission
- Dyno Sheet
- Mod list with Fuel type
- Picture of Supra
Top MKIV's:
1: insanearmer, White 95 US-Spec, 1077 whp @ 30 lbs on E-85, BW 82mm T6 Billet Wheel, 6 Spd
2: Ryan, Red 96 J-Spec, 902 WHP @ 35 lbs on E90, PTE 6466 0.81 A/R, 6 Spd
3: James, White 97 US-Spec, 863 whp on E85, GTX4202R, 6 Spd
4: Toby, Green 97 US-Spec, 751 whp @ 29 lbs on C16, ITS/Comp 74mm, 6 Spd
5: Silviadrftr, 94 Black USDM, 730 WHP @ 29 PSI on MS109, BW S475, 6 Spd
6: Josh, 94 Alpine Silver J-Spec, 715 whp @ 27 lbs on 94 + Meth , PTE 6466 1.00 A/R
7: Shaun, 93 RSP Blue J-Spec, 700 whp @ 25 lbs on Pump 94, BW S467.7 FMW, 6 Spd
8: Bruce_Wayne, 93 Black Hardtop US-Spec, 456 whp @ 18 lbs on 93 Oct, Sp Torque Monster Kit, PTE 6266, 6 Spd
Top MKIII's:
1: Duane, 1989 White , 1036 WHP @ 32 lbs, GT4202, 5 speed
2: CzA, 1989 2JZ, 577 WHP @ 20 lbs, GT40R88, Stock JDM Cams
3:
4:
5:
Top MKII's:
1: Bruce R, NFLD, 1982, 450 [email protected] 19 lbs, HKS Twins Kit, R154, 1JZGTE
2:
3:
4:
5:
Discussion Starter #2 (Edited)
Probably not even top 20 LOL
Shaun , Calgary / RedDeer , AB.
RSP Blue 93 Supra TT Hardtop
3.0L Bonestock unopened , GT3582R 0.82 A/R (Tial stainless Vband hotside , Custom EPIC welding Manifold) , 6-speed
Made 489 whp at 18 lbs on pump (DynoDynamics). Best 1/4 - [email protected] (no launch control 1.90 60')
Shaun, This shoudn't even count considering what you have in store. ;)
Well.... I can update when the day comes :) , But thats my current last "running" setup .
Glad to see someone take the reigns on this list ,, Thanks Awalus !
I'll add the MKIV when the upgrades are complete and I have results.
- Name and Location : Bruce R. NFLD.
- Generation of Supra : 1982 MKII
- Motor,Turbo and Transmission 1JZGTE/ HKS Twins/ R154
- Dyno Sheet : Attached
- Mod list : HKS T3G kit/ HKS Manifold/ Raptor 3" SS Exh/ Sard 650/ Greddy EMU/ Mines ECU/ UR Gears/ 2J Cams/ AEM Meth Inj.
- Picture of Supra : Attached
YES still #3 !!! LOL
We can add Toby 751hp Green MK4 C16 [email protected] ?? i believe ...fastest supra in alberta officially !!! maybe toby can confirm ... Comp 74mm ??
Discussion Starter #13
Shaun, I will let Toby confirm the numbers before i add him to the list.
Artur
Tommy Van
Vancouver Canada
1994 C spec lhd 6 speed Mk4
I just completed my build recently and car made 1036 rwhp at 30 psi.
Here is the mod list.
-Fully built 2jz 10:1 compression
-Head games full race head with Ferrea valve train and +1 valves.
-HKS 272 cams
-Titan head gasket
-Titan oil pump
-Titan crank pulley
-Unorthodox racing cam gears and pulley set
-Virtual works exhaust manifold
-Virtual works upper and lower water necks
-Virtual works 4.5 " downpipe and mid pipe
-Ross machine racing intake manifold
-Tial 60 mm wastegate
-Tial BOV
-Custom 4.5 " Garrett intercooler pipes ( V-band )
- GT47-80 dbb turbo
-HKS 4" titanium exhaust
Fuel system
-ID 2000 cc injectors
-Virtual works triple denso hanger with all braided lines in tank
-Triple denso pumps (2 constant feed, third boost activated by ECU)
Suspension and drive train
-Boost logic driveshaft
-Carbonetecs 2 way LSD
-RPS triple billet carbon clutch
-Titan line lock
ECU
-AEM infinity ecu with full custom harness to run flex fuel and traction control
-Haltech ethanol Content sensor
I'm sure I'm missing a few things. The car has just been finished being built and put down 1036 rwhp at 30 psi on e85, the engine definitely still has a lot in it left but for now I'm very satisfied with these numbers. Can't wait till spring/Summer to see what it'll do at the track.
Car was sold, location unknown.
Discussion Starter #18
Tommy,
Very nice build. Lots of potential.
May I ask how large the 4780 is? That can't be very Street friendly in the Vancouver area!
Hey Artur thanks for the add.
Originally when we built this 3.0 2jz with the GT47-80r, we thought it was going to be laggy as hell and full boost should hit around 5800 + rpm. However with the high comp 10:1 it helped a lot, i see full boost alot sooner then expected at 5100-5200. It is a 80mm with a .96 hot side.
1 - 20 of 69 Posts
