41 - 60 of 69 Posts
Update the list with what??
Hi Artur, can we get Nick's added to the list? We made 1077whp @ 30psi with it last night.
Gen: '95 MK.IV Toyota Supra US-Spec
Engine/Turbo/Trans: 2JZ-GTE, Borg Warner S482 Billet, V-160
Dyno Sheet: See Video Link Below
Fuel Type: E85
Mod List:
- Microtech EFI LT-15C w/ X6 Igniter Box
- Force-Fed Racing Custom Built Engine Harness
- Force-Fed Racing Custom 3" SS Intercooler Piping
- 2JZ-GTE Factory Block/Mains/Crank
- Oversized Valves
- Wiseco Pistons (bored 0.10 over)
- Eagle Rods
- ARP Hardware
- 272 Camshafts
- OEM Toyota Headgasket
- OEM Ignition Coils
- Powerhouse Racing Intake Manifold
- Twin-Gate Exhaust Manifold
- Borg Warner S482 Billet (Small Cover)
- Boost Logic 4" Exhaust
- RPS Twin-Plate Clutch
- ID2000 Injectors
Footage of the beast on the dyno including dyno graphs:
This was our first bout tuning on E85 and even with a fairly conservative tune-up we were quite pleased with the results :) Nick definitely knows how to drive so it should be a blast working with him to get this thing down the track!
Discussion Starter #48
Fuel Type: E85
Mod List:
- Oversized Valves
- Eagle Rods
- ARP Hardware
- 272 Camshafts
- ID2000 Injectors
Nicely Done.
Hey guys,
Got some new numbers this year... 902whp / 746wtq
Ryan Sammut
1996 JDM RZ
Built 3.0 , Precision 6466 , 6 speed Getrag
10:1 CP pistons .20 over with .250 wrist pins
BC HD H-Beam rods with 625+ rod bolts
Stock crank / Stock main caps / ARP main studs
Head - Stock, not ported / BC272 cams / BC single spring kit with titanium retainers / Stock cam gears
625+ Head Bolts
Stock ignition - NGK Iridium Heat range 8 gapped at 0.18
ProEFI 128 - Logger display / map, fuel press,coolant press, oil press, iat , 3 port bcs / Continental Flex fuel sensor
FSR fuel system - Twin Walbro E85 pumps staged (stock hanger) / FID2000cc injectors / Additional -6 feed + Stock feed & return.. Additional upgrades - Fore innovations filter / FuelLab FPR.
FSR cast manifold with a PTE 6466 .81 a/r.
3 inch exhaust, DP and MP / 2 inch exhaust cutout on DP boost activated at 4 psi / PTE 46mm wastegate open dump
Stock intake manifold with removed TRAC butterfly
ETS 4 inch FMIC kit
Real St catch can with -10 fittings and PVC valve routed to intake valve cover hose
South Bend Stage 3 Endurance clutch / DM stock flywheel / 6 speed Getrag
Fuel - Ignite Red E90
Ryan
Not real exciting in the MKIV world, but its damn fun so far
Rocky, S.S.M ON
-93 MKIV us-spec hardtop 6spd
-stock engine, intake and fuel system
SP torque monster kit (cast mani, qsv,6266 precision, 4"mp/dp)
ETS fmic, AEM V2
-456whp 426wtq @18psi on 93
Tuned by Larry @SP
New Supra owner from Calgary, bought this car off a member from edmonton a few weeks ago, changed some stuff up and had it re tuned...it's a 94 USDM targa, s475 turbo, ID1000, stock bottom end, 272 cams with springs/retainers etc etc Tuned at Vex in Calgary!
Discussion Starter #54
Welcome to the family Silviadrftr. Added you to the list.
Discussion Starter #55
Bruce_Wayne,
That is z beauty. Show us some more pictures of your unicorn.. Love it.
Thank you! I recently did a half mile up here in Calgary and managed a 253 km/hr with the coil packs breaking up....I have a new ignition setup waiting to go in, just need some time to do it, as well as my meth kit that's sitting in my garage! Defiantly loving the car that's for sure!
Update , 700whp , BW S467.7 FMW , 94 pump , 25-26psi .
41 - 60 of 69 Posts
