I'm trying to get these ten screws off to take the cover off, but some off them are really on there tight. I've tried WD-40, etc. I'm really worried that I may strip one of them. Is there a easier way to take them out?
Thanks,
Thanks,
They should be allen bolts, if you get the proper size allen wrench in there, they shouldn't strip out on you.
Good luck.
Supra OG
Give it some more force. They will all of a sudden break loose. The allen head screws go into a metal insert in the plastic. Can't imagine you could break the insert loose before breaking the screws loose.
Put some muscle into it. :D Actually one of mine were stripped from the previous owner and I had to drill the screw out to get it off.
