1 - 20 of 326 Posts
Administrator
A few forum members brought to my attention there isn't much of a definitive list of discontinued parts for the MKIV.
The purpose of this thread is to list out any known or omitted parts without much discussion other than just that. If not sure if something is discontinued, message me and I'll confirm if it is or not and add it.
Please also post the Toyota part numbers if you have them.
This will be an evolution and I will update as time permits and I am taking the info from many existing threads.
The second phase of this thread will be links to aftermarket alternatives to any of the parts discontinued listed next to the OEM discontinued part.
Thanks,
Matt
Interior/Trim Parts
1993-96 Specific
Premiere edition logo on ash tray
55420-14040 Panel Ctr Dash List 64.42 Cost 49.19 [ discontinued ]
55410-14510 Panel Top Dash List 157.25 Cost 120.05 [discontinued ]
55404-14530 panel sub left side dash panel [discontinued ]
74320-14700-c0 sunvisor, left [discontinued ]
74310-14640-c0 sunvisor, right [discontinued ]
55537-14030 heater switch cover [ discontinued ]
1997-98 Specific
55404-14570 Panel Lh Dash [ discontinued ]
55420-14060 Panel Ctr Dash [ discontinued ]
55405-14170 Panel Rh Dash [ discontinued ]
55410-14530 Panel Top Dash[ discontinued ]
58804-14100 Panel Console 6 Speed With Boot[ discontinued ]
58804-14110 Panel Console Auto [ discontinued ]
74102-14140 Ash Tray[ discontinued ]
74232-14121 Panel, Lh Door Switch [ discontinued ]
97-98 dash plugs under radio in gray [discontinued ]
97-98 polished 17" wheels [discontinued ]
74310-14642-C1 - RH Sunvisor [discontinued ]
1993-1997 MODELS
84310-1B120 - MULTI-FUNCTION SWITCH
84112-80152 - LIGHT SWITCH
84329-14030 - TURN SIGNAL SWITCH
84652-14620 - Wiper Switch
84140-14100 - Headlamp/Dimmer Switch
All Years
Coil Pack Cover (the green one) 11304-46050
Targa Air/wind Deflector "eyebrows" PN 63230-14040
Rear seat foam
ALL factory leather seat covers front and rear
Overhead map light
Tan seat track plastic covers
93-98 FLOOR MATS
45100-14630-C0 STEERING WHEEL
rear speaker assys with black plastic encloseure
rear trunk/hatch carpet
AC Evap/heater Box assy
16400-46430 Radiator Turbo Auto
Rear Bumper cover - all years discontinued
87615-24020 -DISCONTINUED- RETAINER, INSULATOR -This is the piece that surrounds the heater core hard lines that come out from the firewall
82871-24490 -DISCONTINUED- PROTECTOR, WIRING HARNESS-This is the plastic shield/surround that goes on the front right hand apron for the chassis harness.
Toyota Part No.: 69030-14260 LOCK ASSY, FRONT DOOR, RH [DISCONTINUED]
Exterior/Trim Parts
Gold emblems [discontinued ]
Transmission Parts
93.5-98 5 speed manual gear box[trans] [ discontinued ]
33030-0w212 v160 6spd transmission assy [ discontinued ]
93.5-98 na 5 speed LSD diff assy [ discontinued ]
33370-0W010 HUB ASSY, SYNCHRONIZER, NO.2
90069-10011 BEARING
90069-10019 BEARING
Counter shaft assembly 33421-0W060 [ discontinued ]
6TH gear Counter 33429-0W010 [ discontinued ]
5th gear Counter 33428-0W030[ discontinued ]
1st gear driven 33032-0W030[ discontinued ]
Suspension/Chassis Parts
93-97 Rear lower control arms (shock and knuckle attach to) Discontinued
48730-14030
48740-14060
Engine Mechanical Parts
Engine lift hooks on cylinder head.
Body/Frame/Crash Parts
97 Anniversary emblems on fenders
Pearl white side scoop extractors LH and RH
LH frame rail assy to fire wall
right rear qtr panel outer wheel house
Engine/Body Electrical Parts
97-98 Harnesses discontinued
82121-1B112 - Wiring Harness Engine 6 speed
82121-14891 - Wiring Harness Engine Auto
84988-14020 - Trac On/off switch [discontinued]
Blower motor 87105-14050 FAN SUB-AS SPORD
complete key cylinder set (all doors + ignition) PN#6900514690
Main engine compartment wire harness for turbo
88002-14030 CRUISE CONTROL UNIT [discontinued]
47990-14010 Trac Actuator [discontinued]
TRD Parts
Ptr04-00026 trd lsd a list 1582.11 cost 1186.58 [discontinued ]
TRD Tachometer
Going for broke
Floormats, rear hatch carpet, TRD single-disc clutch...
Cardinals!
- Left & right interior door panels.
About 98% sure all of these are long discontinued..
- Euro hood scoop's under hood air deflector.
- Glove box
- Headliners
- A/C control unit
Captain Hammer
- A/C control unit
The AC Amplifier? Just got one in today brand new from Toyota.
Here's a list from the local Texas Supra page. Many have been mentioned already:
Gold emblems
SE side stripes
Floor mats
Limited edition logo on ash tray.
93.5-98 na 5 speed LSD diff assy.
LH dash panel Gray 97-98
Console bezel ATM and MTM gray 97-98
AC Evap/heater Box assy.
Overhead map light.
Front end mask [bra]
Alarm systems with and with out keyless entry.
ALL factory leather seat covers front and rear.
Main engine compartment wire harness for turbo.
LH frame rail assy to fire wall.
97-98 dash plugs under radio in gray.
rear speaker assys with black plastic encloseure.
Baltic blue touch-up paint.
rear trunk carpet .
evap drain hoses.
right rear qtr panel outer wheel house.
The metal plate on the firewall that goes around the heater core hoses in the engine bay and the rubber gasket beneath
Administrator
Discussion Starter #9
Are we also going to count all the electronics such as factory sub and HUs?
All discontinued parts, so yes.
Theres many small things people aren't aware of that are discontinued.
Also anyone just posting please check the list before adding the item.
Matt
Administrator
Discussion Starter #10
Shift knob
Shift knobs are now discontinued?
Also center 'crotch' vent panels, and rear quarter, front windshield, glass interior plastic panels are discontinued.
Glad I got my parts for my 6 speed swap! Better now than feeling sorry later.
I also ordered a 6 speed shift knob... So it ain't discontinued. Yet.
Can you give me the part number for the shift knob? I need to jump on this as mine is showing wear and I would like to replace it.
6spd shift knob is not discontinued.
Part number is 33504-14130
Cardinals!
The A/C control unit. The electronics assembly behind the dash panel that has all the buttons for controlling the A/C:
55900-14520 HVAC Control Head Assy List 862.37 Cost 620.00
Listed as discontinued on this site and a few members have tried to order it recently and have been told it's discontinued at local dealers:
http://www.toyotapartsdeal.com/oem/toyota~control~assy~air~conditioner~55900-14520.html
Here's a new post by a member asking Elmhurst about that part number.. wait for a response for official verdict:
http://www.supraforums.com/forum/showthread.php?967338-MKIV-HVAC-price-quote
Captain Hammer
V160 countershaft.
Here are the hard parts that are discontinued on the transmission.
Although we will soon have stock fitment gears to replace every gear in the V160, designed so you don't have to buy a complete gear set to repair.
Inline for the win
Blower motor
V160 Parts:
90069-10011 BEARING
90069-10019 BEARING
Can anyone confirm if the TRD tach is now totally discontinued?
Per MVP's site....
Part #: TRD Tach Supra 6
Product: SOLD OUT AND DISCONTINUED!!
Your Price: $500.00
:sadance: I lucked out then. Got mine about 3 weeks ago, but from someone else.
Administrator
Discussion Starter #19
The trd tachs I believe can still be purchased by a dealer I believe at 50 pieces at a clip to make a run of them Cost is around $150 a piece believe it or not. The markup on them is huge
Master Shit Fixer
According to Robert at MVP, the company that made them for TRD is out of business.
1 - 20 of 326 Posts
