301 - 320 of 352 Posts
Master Shit Fixer
What’s the quote on the seat belts? My local dealer said $181.66.
Master Shit Fixer
we have the last 3 drivers side seat belts in the country. no other dealers have these in stock and there is only 1 currently on ebay
Master Shit Fixer
  • Like
Reactions: saiyajinimports
Damnit! I missed the eBay one by like 2 seconds. Now 0 available on eBay.
I saw it there a few days ago, but didn't know it was discontinued. Oh well. Add it to your parts reproduction list Toyota.
  • Like
iSPOOL
Its probably easier to list parts that AREN'T discontinued at this point in time. ?
  • Like
A few forum members brought to my attention there isn't much of a definitive list of discontinued parts for the MKIV.
The purpose of this thread is to list out any known or omitted parts without much discussion other than just that. If not sure if something is discontinued, message me and I'll confirm if it is or not and add it.
Please also post the Toyota part numbers if you have them.
This will be an evolution and I will update as time permits and I am taking the info from many existing threads.
The second phase of this thread will be links to aftermarket alternatives to any of the parts discontinued listed next to the OEM discontinued part.
Thanks,
Matt
Interior/Trim Parts
1993-96 Specific
Premiere edition logo on ash tray
55420-14040 Panel Ctr Dash List 64.42 Cost 49.19 [ discontinued ]
55410-14510 Panel Top Dash List 157.25 Cost 120.05 [discontinued ]
55404-14530 panel sub left side dash panel [discontinued ]
74320-14700-c0 sunvisor, left [discontinued ]
74310-14640-c0 sunvisor, right [discontinued ]
55537-14030 heater switch cover [ discontinued ]
1997-98 Specific
55404-14570 Panel Lh Dash [ discontinued ]
55420-14060 Panel Ctr Dash [ discontinued ]
55405-14170 Panel Rh Dash [ discontinued ]
55410-14530 Panel Top Dash[ discontinued ]
58804-14100 Panel Console 6 Speed With Boot[ discontinued ]
58804-14110 Panel Console Auto [ discontinued ]
74102-14140 Ash Tray[ discontinued ]
74232-14121 Panel, Lh Door Switch [ discontinued ]
97-98 dash plugs under radio in gray [discontinued ]
97-98 polished 17" wheels [discontinued ]
74310-14642-C1 - RH Sunvisor [discontinued ]
1993-1997 MODELS
84310-1B120 - MULTI-FUNCTION SWITCH
84112-80152 - LIGHT SWITCH
84329-14030 - TURN SIGNAL SWITCH
84652-14620 - Wiper Switch
84140-14100 - Headlamp/Dimmer Switch
All Years
Coil Pack Cover (the green one) 11304-46050
Targa Air/wind Deflector "eyebrows" PN 63230-14040
Rear seat foam
ALL factory leather seat covers front and rear
Overhead map light
Tan seat track plastic covers
93-98 FLOOR MATS
45100-14630-C0 STEERING WHEEL
rear speaker assys with black plastic encloseure
rear trunk/hatch carpet
AC Evap/heater Box assy
16400-46430 Radiator Turbo Auto
Rear Bumper cover - all years discontinued
87615-24020 -DISCONTINUED- RETAINER, INSULATOR -This is the piece that surrounds the heater core hard lines that come out from the firewall
82871-24490 -DISCONTINUED- PROTECTOR, WIRING HARNESS-This is the plastic shield/surround that goes on the front right hand apron for the chassis harness.
Toyota Part No.: 69030-14260 LOCK ASSY, FRONT DOOR, RH [DISCONTINUED]
Exterior/Trim Parts
Gold emblems [discontinued ]
Transmission Parts
93.5-98 5 speed manual gear box[trans] [ discontinued ]
33030-0w212 v160 6spd transmission assy [ discontinued ]
93.5-98 na 5 speed LSD diff assy [ discontinued ]
33370-0W010 HUB ASSY, SYNCHRONIZER, NO.2
90069-10011 BEARING
90069-10019 BEARING
Counter shaft assembly 33421-0W060 [ discontinued ]
6TH gear Counter 33429-0W010 [ discontinued ]
5th gear Counter 33428-0W030[ discontinued ]
1st gear driven 33032-0W030[ discontinued ]
Suspension/Chassis Parts
93-97 Rear lower control arms (shock and knuckle attach to) Discontinued
48730-14030
48740-14060
Engine Mechanical Parts
Engine lift hooks on cylinder head.
Body/Frame/Crash Parts
97 Anniversary emblems on fenders
Pearl white side scoop extractors LH and RH
LH frame rail assy to fire wall
right rear qtr panel outer wheel house
Engine/Body Electrical Parts
97-98 Harnesses discontinued
82121-1B112 - Wiring Harness Engine 6 speed
82121-14891 - Wiring Harness Engine Auto
84988-14020 - Trac On/off switch [discontinued]
Blower motor 87105-14050 FAN SUB-AS SPORD
complete key cylinder set (all doors + ignition) PN#6900514690
Main engine compartment wire harness for turbo
88002-14030 CRUISE CONTROL UNIT [discontinued]
47990-14010 Trac Actuator [discontinued]
TRD Parts
Ptr04-00026 trd lsd a list 1582.11 cost 1186.58 [discontinued ]
TRD Tachometer
Air inlet hose as well 17805-42011
17341-42020
Administrator
Discussion Starter · #316 ·
Are front bumper covers discontinued I tried to contact a dealer about one and they said it was.
93 to 96 yes 97 98 still available.
Smith & Wesson Member
85381-14020-C0 - Black
Windshield Washer Nozzle Sub Assembly
  • Like
Reactions: FasTTurbo
Dr. Jeff Lange
Alternate Part Numbers (50060 for example is a more modern design). All in the correct paint colour. May not all be available, may not be available in North America.
85381-14040-C0
85381-30040-C0
85381-30070-J0
85381-43010-C0
85381-50040-C0
85381-50060-C0
85381-51010-C0
Jeff
  • Like
Actual member since 2001.
Funny thing is you can find a lot of these parts are available online if your willing to pay the "Supra Tax" and the shipping from other countries.
Pay to Play
