Well, there is snow on the ground, it is about 15 degrees outside, I haven't reactivated the insurance on my car, I still have short little wheel studs on the rear, and I hadn't finished hooking up the tach signal to my additional injector controller....
... but I couldn't help it. I took my new NA-T out for a little spin and let me tell you:
HOLY SHIT
I have the soft spring in my TiAl 40mm wastegate (5.6psi) and didn't have the MBC cranked up so I was running low boost, but man oh man what a difference. In 3rd gear at 40 mph with just half throttle, there is about 1.5 seconds of lag then the boost jumps up and it is like you turned on another engine
I need to:
1) Finish wiring the AIC so that I can run some real boost without blowing up the engine (waiting on Dave "Couldn't have done it without you" Henry to let me know where to get the tach signal off the igniter)
2) Have a bead welded on the end of my charge pipe (popped it off on the last pull)
3) Get the longer wheel studs mounted on the rear wheels
4) Crank up the MBC to 14.7 psi and hold on tight...
Thanks to everyone who has helped me with technical questions and with good deals on new and used parts. As for anyone else who is contemplating doing this, you might think I would recommended it, but I can't say I do. I had all Winter to do the job, so there was not a lot of pressure to get it running since I couldn't use it, but I still spent just about every free moment working on it, and all the rest of the time worrying about the next step. And it wasn't cheap. I probably spent in the neighborhood of $6000 on the turbo related portion of the project. Hell, the UPS man practically wore ruts in the driveway. If you buy a kit it will save a little frustration, but be patient - it is far from a bolt on job.
As soon as the weather improves I will get some pics and some high boost impressions posted.
Peace,
Scott
HOLY SHIT
I need to:
Peace,
Scott
